Tom Pullizzi |
Generally this is because of passivation layer loss by operating one of the feed with out passivation air Presence of iron in feed also causes stress corrosion Construction material may be defective partially say at the bottom Please furnish material of construction.
Stefen Edward
- Edingburg, Scotland
Normally uneven corrosion occurs due to poor feed rate and quality, N/C ratio; high inert; chloride and sulphides and also iron precipitated water.
1. Increase liquid ammonia rate
2. Maintain volumetric flow rates
3. Complete primary reaction at the shell level
4. Keep mole ration above 4.4
5. Prevent iron precipitated water
6. Check CO2 purity - 99.3%
Mike Rowdsger
- Tampezeal, Austria
Normally high corrosion speeds in urea synthesis equipment occur
due to lack of passivation.
316 L Urea Grade needs a continuous oxygen suppletion to assure a
passive layer builds up.
What are the temperatures in the reactor bottom ?
Mark Brouwer
- Maastricht, The Netherlands
Save
This Page (why?) - Home - ©1995-2009 finishing.com
