HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 10012
Field applied Galvanized Zinc Coatings?
I am needing information regarding a coating that can be applied to carbon steel to prevent corrosion when exposed to water. I was thinking that a galvanized zinc coating would work but I'm not sure that such coatings are available outside fabrication. Also what kind of surface preparation is required before application of the coating(s)?
Dana C [last name deleted for privacy by Editor]- Mcallen, Texas
May 23, 2008
Hi, Dana. You are correct that galvanizing is a factory-applied finish. The metal must be pickled and cleaned, then fluxed before dipping into the molten zinc. The closest you will get for field application is a cold galvanizing spray [linked by editor to product info]. This is sprayed on like paint, but is very rich in zinc for galvanic protection of steel. Good luck.
