finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 10000
How to get Tight Nickel Plating Thickness Tolerance?
I am working with various electroplating companies to coat nickel on thin sheets of material that are roughly 48" x 48" x 0.06" thick. Aim is to get 200 (+100, -0) microinches of plating thickness. Edges are masked to prevent material build-up. Nevertheless, I'm told thickness variation can be as much as 400 microinches across the entire surface.
Is this reasonable?
Can this be controlled better (+/- 50 microinches)?
How can one accurately measure the variation non-destructively?
David K [last name deleted for privacy by Editor]
- Columbus, Ohio
It would take thieves and shields to do it and that can be a large pain. Simplest is to just use electroless nickel. Costs more, but is superior in nearly every way.
One problem with electroless nickel is that its melting point is below 1000 C ---bad news for me. I've got to have the electrolytic. So...my original question, can you control it to +/- 50 microinches?
Suggestions for sources?
- Columbus, Ohio
Ed. note: The site's supporting advertiser Hill-Cross is a jobshop with highly specialized experience in Nickel Boron plating.
Dave:
It can be done by means of a time consuming preparation work of anode placing and thieves (something most platers just hate) and a good help from statistical laws (cross fingers). There are two other ways also expensive but worth exploring. Electroless nickel- boron (melting point is 1,080 C) and over plating and then grinding your actual electro-nickel.
Good luck, Guillermo Marrufo
Monterrey, NL, Mexico
I agree. Thieves and shields take a lot of trial and error. This will cost a chunk of change! Virtually any good plating book will have a chapter on this subject. AESF has a neat pamphlet for sale on this subject.
What causes it is a science. How to correct it is an art. James Watts
The thickness variation is often a problem resolved by subsequent grinding. When we use the Chemical Vapor Deposition process to grow nickel shapes, or coatings, on complex pieces, the variation can be only as close as +/- 0.005 inch. The main variable is the uniformity of heating of the substrate (to 350 deg.F) for the CVD process, but the nickel does grow very fast - at a rate of 0.010 inch per hour.
Cheers,
Mick O'Meara
- Toronto, Canada
